Whats wrong with my 2500d?
melnlovr911
Alright I have a New Orion 2500D. I installed it in my geo storm with 0 gauge turning into dual 4 gauge for power. I have a good ground. Its wired to 1 ohm on 2 3515's in a wall. I previously had a coustic 600 watt amp and the coustic was louder then the orion. I dont even hear any sound untill the gain is 3/4 the way up. voltage was steady around 13 v.
So I decided to install it in my other car.
Installed it in my bravada on 2 12" memphis M3's. Had it wired to 1 ohm with power and grounds running straight to amp (fused of course). Same with this install. you dont hear anything at all untill gain is 3/4 of the way up. Mind you my head unit is on 40. Now with the gain all the way up and my sub set on +4 on my head unit it gets kinda loud but not what I would expect from this amp. and voltage doesnt drop below 14 volts in this car.
Any suggestions?
yes i have both power and grounds in. I didnt set the gains with a dmm yet but its still not that loud with the gain turned all the way up. Im not a newb just never used a dmm.
im bettin that u have somthing messed up on ure wireing config.... that is what i would check.... 2500d should perform a hell of alot better then that.. for all u know its messed up and like running at 4 ohms or somthing
melnlovr911
melnlovr911
Louisville, KY
HCCAfan
