Whats the difference between SD 5k EVO and SD 5K POWER
Could someone please explain the difference between the two amps? I've mainly dealt with korean amps over the years but I'm wanting to get into the brazilian amplifiers. I ordered a SD 5K EVO X. The only difference I saw between these two at a quick glance was the SD 5K POWER had dual power and grounds where as the SD EVO has single power ground. Are there any other differences between them? I plan on running my SD 5K EVO X with a FI TEAM 4.
The Evo line is the first on to have Hi-fi (high fidelity) performance even in the highest power rates with a THD (Total Harmonic Distortion) under 0,025%. It also has a patented harmonic alignment processing that places it above any similar product in the world market.
Now featuring a linear power supply with an efficiency over 90%, it is able to produce solid and longer bass sounds with the lowest consumption ever. When in standby, it can consume up to 5 times less than other products in the market.
This is what I found so maybe that’s the difference?
frenziedhstge
Littleton Co
