What's the best adhesive to use for tweets?
  • 4
mav2002
Okay, so I am way new to this, but had an install question. I have a 2003 BMW and had my rear tweets replaced. I left my car outside in SoCal the other weekend, and it got upwards of 110 degrees OUTSIDE, which probably means what, 140+ inside? Anyhow, my freakin' tweets basically fell out! After looking more at the tweets, they were hanging by the wires (+/- wires) and it looked as if the adhesive melted away. Do car install shops use adhesive to keep these in place?
If I were to do this myself, what kind of adhesive should I use? In case your wondering, the speakers are Diamond Audio s500s speakers.
Help!
check out 3M double sided foam mounting tape. this stuff can handle quiet a bit of load on it. also check out 3M's interlocking plastic velcro. i have used this stuff to mount a lot of things, even my ignition in my car. when it came time to remove it, i had to pry it off with a screwdriver, lol
My vote would be for RTV. Certailnly strong enough for a tweet, good temperature rating, and not totally permanent like epoxy.
too messy. and it is too soft, when mounting something, i would want it to for sure stay in the same place i put it. i have used it before and it is not a stable enough base for them to rest on. you would have to mount them two or three times to get the adjustment just perfect, where as velcro or mounting tape would be much easier.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
625
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
930
mav2002
mav2002
Los Angeles, CA
bri487
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
