1. When have you heard a Brahma ?2. yes it is the best in the categoryW6's are good, Type R's are good. Shivas wont handle 600 thermally. Brahmas are way too loud, but at 600, would be a waste. SE's in about .7 cubic feet..... At 600 a brahma wouldnt work that well, but, its prolly the best overall sub in the category.
Brahmas work great at 600. Shivas are rated for 650rms and would handle more, although its usually not needed to get full output unless were talking a VERY small enclosure. And brahmas are not way too loud one brahma would have some output but also the best sq of the choices..... its hard to beat xbl^2 in sq.W6's are good, Type R's are good. Shivas wont handle 600 thermally. Brahmas are way too loud, but at 600, would be a waste. SE's in about .7 cubic feet..... At 600 a brahma wouldnt work that well, but, its prolly the best overall sub in the category.
1. Shiva- 650 MAX , 375 RMS //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif2. XBL^2 Rulez !!Brahmas work great at 600. Shivas are rated for 650rms and would handle more, although its usually not needed to get full output unless were talking a VERY small enclosure. And brahmas are not way too loud one brahma would have some output but also the best sq of the choices..... its hard to beat xbl^2 in sq.
The Shiva is a 12" dual voice coil subwoofer. It has 16mm of one way Xmax. Stamped frame, paper pulp-based cone, foam surround. Semi-progressive spider. Dual 2" diameter 8 Ohm voice coils. 87 dB efficient. 20 Hz to 1 kHz. Good for sealed boxes from 35 to 100 liters, vented boxes from 85 liters to 150 liters, and infinite baffle. Fs 21 Hz, Qms 5.5, Qes 0.42, Qts 0.39, Re 5.5 Ohms per voice coil, Vas 155L, Sd 481 cm2, 650W RMS.1. Shiva- 650 MAX , 375 RMS //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif2. XBL^2 Rulez !!
3. Id def get something from Adire Audio, there woofers are more focused on SQ.
Your preachin to the choir.Ive seen those specs many a timesThe Shiva is a 12" dual voice coil subwoofer. It has 16mm of one way Xmax. Stamped frame, paper pulp-based cone, foam surround. Semi-progressive spider. Dual 2" diameter 8 Ohm voice coils. 87 dB efficient. 20 Hz to 1 kHz. Good for sealed boxes from 35 to 100 liters, vented boxes from 85 liters to 150 liters, and infinite baffle. Fs 21 Hz, Qms 5.5, Qes 0.42, Qts 0.39, Re 5.5 Ohms per voice coil, Vas 155L, Sd 481 cm2, 650W RMS. Shiva 12" NORMALLY $125.00 Shipped
http://www.visionaryaudio.com/adire.htm
Below_30 0wn3s j00 !!"375W per voice coil; 650W total to the driver"
