Depending on the amp, most 5k amps can handle .66 which you could get from 6 of the d2's wired series/parallel. With 6 of those subs and 5k you should be able to break a 150 legal assuming the box is good. Option #2 would be my pick by far.
you know the max box size that fits for sure lol i finally figured that out about 2 months ago. how did u fit it through the trunk being 19.75 deep?If you have the 4-dr...try a box like this,
16.5"t x 37"w x 19.75"d....double baffle.
Subs on passenger side, have to stagger them a little to fit.
Do 2 threaded rods front to back between the subs.
Port on drivers side, 15"t x 6"w...Start w/ 10" deep and tweak from there.
On ~3.5k you should be able to touch 150dB+ around 57hz.
Just talked to NickV, he said he has to pull the plastic trim out near the trunk opening and it will drop in. My have to play w/ it a little though.you know the max box size that fits for sure lol i finally figured that out about 2 months ago. how did u fit it through the trunk being 19.75 deep?
biggest i could get was 16.75x32x 18 (prefab) i know i could go almost 38w.
and when i had my old system in i was peaking a 58hz after we changed the port. i also found a peak at 43hz with a box tuned to 36hz.
josh u added me on facebook. i havent been on in ages. i got on the site last night and its changed alot.Have the alero owners join aleromod(dot)com... we have a million members (slight exaggeration), but probably around 10 with something considered an aftermarket soundsystem. We need more knowledgable people in the audio department. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i don't expect that now. im going with elemental designs e3.6's.lulz, i hope if your going with cheaper shit like that, that oyu dont expect 150's
