Whats deeper? 2 - 12's or 1 - 18
Originally posted by BonusBobo they sound ruff because he ported SQ subs.
it'll only sound bad if he doesn't build the box correctly. i have the same pioneers (10's) and they are in a ported box. the bass is absolutely accurate, even at high volumes.
Acutally my subs are in a custom sealed/ported box haha.
Its LOUD! but sounds brutal. When you crank it, you get a full back massage. THats the only nice part
Originally posted by Jmac The 18 would be deeper and get louder. How do you guys figure 12s would be louder ?
Anyways, getting an 18 that sounds good is usually expensive.
Cone area, you ****ing retard //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
ehh....in theory the 18's woould be louder...turns out i was thiking of 15's....but 19's have more cone area than 2 12's.....
and to find out jus multiply the xmax by the cone area....larger number wins the who's louder contest.....
Originally posted by Goddyd4me ehh....in theory the 18's woould be louder...turns out i was thiking of 15's....but 19's have more cone area than 2 12's.....
all in theory though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif (in other words dont let that go to your head...not you personally the other readers of the board)
i own an 18 and it is louder than 2 12s of the same kind...it goes lower and louder...if i want to listen to country or rap or rock or spl(which it does very well in) i can do it...it can be snappy as a 10 or not...depens on the bax and the way it is hooked up(hz)
go with jmac and all of the people who say the same..they and him said what i would have....not very many people own an 18...so some one who just wants to think that they know a lot about them might but not most of the time..
larger cone area=louder
due to excursion differances it may alter..
if you took one fosgate hx2 12 and one hx2 18 and used the same amp each in a ported box the spl is 3 bd different..18 is louder..that it 2x louder
D
Originally posted by B&R Innovations So by your theory...
The only thing that makes a sub louder is conesize
Seemsa little off tome
BUt i guess if it's the same driver all across...then sure a 13"Focal would movem ore than an 11 1/2
alot of these things are off a little bit more then a LITTLE:p
QuadPioneer
Spinnin' Tracks on Flat
QuadPioneer
Canada
NDMstang65
