Yeah I figured you can tighten threaded rod too so it seems easier to apply. But like you said it's visible which *****, I'm just trying to make the strongest box I can for competition and I figure: Double Baffle, Threaded Road/Wooden Dowels, 45's, Fiberglass Resin and maybe use 1" MDF instead of .75" if Home Depot ever gets it back in stock, any suggestions to make a stronger box?No experience with it but id say threaded rod would be the strongest. The only downside is you can see it on the outside.
Not true... its easy to counter sink it. Ive used both and i have to say the threaded rod really does do the job if you use it right and its a decent diameter, wood works good too and can be cut into very good braces if done strategically. 2x4s or somethig of that nature on the other hand take up more airspace but thats really the only downside to that ive encountered. So i vote user preferenceNo experience with it but id say threaded rod would be the strongest. The only downside is you can see it on the outside.
I don't really care about the looks too much and I CAN counter-sink I'm sure with no problems so I guess I'll give threaded rod a try.Not true... its easy to counter sink it. Ive used both and i have to say the threaded rod really does do the job if you use it right and its a decent diameter, wood works good too and can be cut into very good braces if done strategically. 2x4s or somethig of that nature on the other hand take up more airspace but thats really the only downside to that ive encountered. So i vote user preference
How much does that stuff run per 4x8? In maine wood is usually cheaper but compared to .75" MDF whats it go for? I hear it's really strong stuff. Also is it easier or harder to work with? (no pun intended.) as in does it splinter easy or anything like that?Baltic Birch..
MDF is $30 here so I'm guessing Birch will be about $40-50 which isn't too expensive I should only need 2 sheets for my 15's + baffle. Thanks a ton I'll give birch a try and threaded rods.Birch is about 50-60 bucks a sheet. But seeing how MDF is 40 bucks a sheet here. Going with Birch for a few more bucks is an easy choice. Its not as easy to cut as mdf but it does not create the mess that mdf makes.
