What's better - 2 ohm load or 8 ohm load?
people will say that the higher the ohm load the "cleaner" the sounds will be from the speaker, as the amp can play more percisely or something to that affect.
the less the ohm load is to the amp - the more power the amp will give off.
but - if you hook up a ohm load to the amp that is lower than the amp can handle,
it will catch on fire and die. and you will then subsequently die also from this.
sorry.
There is no advantage to running it at 8 ohms.
That amp will probably produce 200w or so at 8.
Run it at 2 with the gain low -- the sub will get plenty of power and the amp will be running at low stress. It is the best option w/o question.
There aren't really any disadvantages to raising impedance.
You won't see as much power from your amps, though.
you're saying that there aren't really any disadvantages to raising impedance? then which load should I go with. 2 or 8?
sorry.
my amp is 750 watts at 2 ohms and 375 watts at 4 ohms. so should I wire the sub to 2 ohms or 8 ohms?
sorry.
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
I could sit a ***** hooker's azz cheeks on my zx750 w/ a 1ohm load and all she would think is ((warm jizzz)) //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Jer510
Slap Addict
Jer510
Oakland, CA
RAM_Designs
