What's a good woofer to use with the Tantrum?
GTO Zeta
Well, I guess I'm back. I'm not really sure what would be the best woofer or woofers for my Tantrum 500.2. I am currently using a Punch HX-2 in a ported box. It sounds pretty sloppy at times, and the higher bass sounds pretty weak. I am going for SQL with some SPL, more importantly SQL. All input is appreciated.
-John
1 12" id max, diamond d6 or jl 12w6 will sound real nice off that amp. Either way make sure you get a single 4 ohm or dual 2 ohm sub for that amp. You'll wan't to run that amp bridged with a 4 ohm load.
Maybe "pretty loud" isn't one of his major goals //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would recommend a SI Magnum for that amp...dual 2, and that amp will do around 500W @ 4.
GTO Zeta
GTO Zeta
Lawton, OK
JimJ
