What's a good amp for..
thecoolest
what's a good amp for these 15" KICKER 06CVX154 Dual 4ohm 2000W subs?
jsut keep the price range around 300$.. don't go to $400 range
i was looking at a ROCKFORD FOSGATE T10001BD MONO-Channel 1000W AMP but that's $430.. i can't afford that
help me out! thanks //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Audioque 2200d($389) or if you want to go cheaper 1200d($249)
i couldn't find any Audioque amps online //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Look at your RMS wattage of them and match that up with an amp, I think those can handle 750 RMS each so 1500 RMS combined. Hifonics amps are relatively inexpensive and perform decent. Check out this one below.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19581
the subs are 1000w rms each so i'd need to find an amp that gives out 2000w rms?
I just bought a PA BAMF 2001/D:
http://www.caraudio.com/forum/showpost.php?p=5174765&postcount=18
The manuals say that this one will do 2200W@1ohm:
http://www.millionbuy.com/pakbamf40001d.html
and this one will do 3200W@1ohm:
http://www.millionbuy.com/pakbamf55001d.html
I'd go with the bigger one if I were you, just to be on the safe side. It looks like they build them pretty well, but if it's still within your budget then better safe than sorry.
I wouldnt go with Power Acoustic, they wont put out nearly as much as they say they do. 2x40amp fuses=1152watts at 100% efficency which it isnt, so figure 80% of that is 921w on a perfect electrical system. My KX550w amp had 2x35 amp fuses and did a little over 700w on the birth sheet. youd probably be dissapointed running 2x1000w subs with an amp like that
I just bought a PA BAMF 2001/D:http://www.caraudio.com/forum/showpost.php?p=5174765&postcount=18
i was about to cop the second one until i read this......
lol
even though i have very little brain smarts to understand what that is.. i just want something that would get the most out of those subs you know
so what about Kole Audio KX15500D?
http://www.millionbuy.com/kolkx15500d.html
it's a 3200 W RMS x 1 CH @ 1-ohms
yes or no?
So how does this Arc Audio amp put out 1000W with only 60A of current?:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6865
actually... 5 40amp fuses, so at 80% efficiency that is approx 2000w... That's also with 12.4v
thecoolest
thecoolest
in yo mama
08redgti
AJ (ACE)
    Jun 28, 2026
