what XOVER do i need for 80-120 htz midbass?
basscort2009
Banned
so i just ordered some mach 5 mli-65 mids and i asked the mach 5 guy what to cross them at and he said there good down to 70 htz.
so where can i find a xover that supports that low of a midbass? the ones i found on ebay (audiopipe) were 500 ht and that the lowest i found. any other websites i can go to?
Why don't you use your head unit to cross them over there? Most HU's have a HPF right around 70hz.
I also have a Memphis CX35 crossover I'd be happy to sell you for a good price. Variable high pass crossover from 50 to 400 hz for your mids. PM me if interested.
so no on the 2 way xover? i have 2 tweeters and 2 mids for the front stage but only 2 channels on my amp left open. thats why i was leaning toward the 2 way. and the parts express ones just say like 2.5k or 3k and ect.... none say 100 htz or anything close.
i guess now i think about it i still need some kind of a xover becuz i have 4 speakers and only 2 channels left on my amp
I just can't wrap my head around how bad you're fucking up something so simple unless I'm totally missing something myself. If you only have two channels left on your amp, they should be used for a set of comps with a passive filter between the tweeter and mid. For the filter between the mid and the sub, you should be using either the head unit or the amplifier's ability to actively adjust the high pass filter for the mid, and low pass filter for the sub, at around the 80hz mark, assuming that's where you would like to cross at. Most four channel amplifiers have built-in HP/LP filters used for exactly that purpose. The type of components to build a passive network at those frequencies are big and costly, not to mention, performance-robbing. Low frequencies should always be handled actively for optimal results.
He only has two channels open and watns to run tweeters and midbass, thats what you're missing, it won't work like u say unless he has an inline passive crossover because his mids need a Bandpass (meaning high and low crossover working together) and his tweeters need a seperate high pass crosssover, not going to be possible with just two channels. Especially if those two channels only have one set of crossovers for them which is pushing it as my Sundown SAX 100.4 has only one crosover for each set of channels, meanign i can either high or low pass, not both and certainly not a bandpass with a high pass at a seperate point.
If his passive crossover has a high pass point at 100 hz for the mid, then no matter what he does he can't cross it over below 100, because the passive is inline and still working, it doesnt matter if his head unit has a hpf at 70, when the audio signal gets to the inline passive crossover the crossover point will then be changed to 100 hz...
He's asking if there is a passive crossover that goes down to 70hz for it's hpf point for the mids, does anyone know where to find one.
From this, I get that he has two remaining channels on an amplifier that has more than two.
As I said, he needs a passive filter between the tweeter and mid and then he needs to use the amplifier's high pass filter. The passive provides the low pass, the amp provides the high pass. Eureka!!! Bandpass.
thanks for explaining that.
yea but i need a passive xover that has a mid xover freq of lower than 500 htz!!! i cant set my HU to 70 htz if the passive freq on the xover is set to 500
Are you running a two-way front stage or a three-way?
Sub-Mid-Tweet OR Sub-Midbass-Midrange-Tweet?
How many amplifier channels total do you have?
If it's four, do those have the ability to HP/LP respectively?
basscort2009
Banned
basscort2009
dallas tx
basscort2009
