What would you recommend
  • 5
Well I can get the kicker for 160, same as ppi, and I intend to run the kicker at 4 ohms, giving me my 600w rms
yeah but thats gotta be used right? what he and i are saying is wire sub to 1 ohm and set gain low on amp don't use any bass boost and amp doesn't draw much more power than it would at 4 ohm with u setting gain to high or using boost to make up for lack of power.. we all use ported boxes which have an issue called box rise when basically only get 1/2 the power amp is so we over power to compensate., they have gotta really good and learning how to do it and it works better because if u have say 300rms to a sub sounds good with a heavy bass track but on say rock music just very little bass there, but if u have more power on tap u can turn sub volume up some make it louder thats what i do..
I understand what you are telling me, and I also understand that some people are having difficulties accepting the fact that I wanted to have a 4 ohm system rather than a 1 ohm, i understand that with the kicker I will have to have the gain set quite low, so as to not blow the sub.
no were saying at 4 ohm u may want to turn gain up to get more power that is readily on tap at 1 ohm..basically u shoulda got a d4 sub and my ppi amp ran it at 2 ohm like me., u would have extra power when needed and not be running amp to hard..
You don't understand the fact that it doesn't make a fuck if its at 4ohm or 1ohm..
Thank you for the help, BOOMINGRANDPA, since this is my first setup, I think that I will just look for a cheap amp that outputs around 700 rms at 1 ohm, since I know eventually I will upgrade to something better. Thanks again
That's not a good idea man, get a good amp that makes power at 1ohm so you aren't stuck with some crap later. You were about to get a good amp, it's only problem. Is it doesn't make power where you need it. Get a decent amp so you aren't trying to trade it after a week
The thing with the ppi is that it outputs 395 at 4 ohms, and 785 at 1 ohm, (12v)
I'm not telling you to get ppi, that amp doesn't really fall under what I consider a quality amp. But with your budget that might be about as quality as it gets. You are not getting a great amp at that price capable of 1000w at 1ohm if you are looking new. You might get a decent one though and ppi would probably be on my decent list, although if I were looking in that range I would lean towards the soundstream.
Soundstream Tn1200.1, ppi, nvx all use the same board and all have decent feedback.
Honestly if my budget was 150, I would buy a good USED amp. I see great deals on here and on Facebook groups all day long. I got an AQ1200 the other day for $75 and it's a beast.
I guess then I will wait awhile and look for some good deals. If nothing turns up, I will just get the ppi, for 170 new
One thing I’ve noticed about reading reviews is those who cannot spell offer very colorful and misspelled adjectives to describe products. Take...
I’ve never owned them but have heard a lot of crossfire products and like them a lot.
22
DeepOhm
DeepOhm
MN
Kam311
    May 16, 2024
    May 16, 2024
