what would you do?
campbell8402
So I ordered a set of components that have a 1/2" tweeter and does not have a surface mount option (only flush)
I have an old beater car with the auto seatbelts so cannot flush mount int the pillars and I'm really not
skilled enough to make a pod
should. I
a: mount in the dash
b: mount on the door
or c: your option
So I ordered a set of components that have a 1/2" tweeter and does not have a surface mount option (only flush)I have an old beater car with the auto seatbelts so cannot flush mount int the pillars and I'm really not
should. I
or c: your option
Why not do an A-pillar mount?? I think those look really clean! & you can have them level with your ears. :)
i am familiar with where the a pillar is but behind the a pillar is where the motor for the automatic seatbelts is located
that was my orgional plan until i made this discovery
i will try the velcro in a few diff spots and suggestion on where i could try?
not sure if this will help at all but the first pic i put up you couldnt see the auto seatbelt i was talkin about
also the plastic trim from the a pillar is all one piece from the a-c pillars and would be a bear to get off even if the motor wasnt right behind where id like to mount the tweeter
what would ya think about mounting it in the door right below the defrost vent for the window? would the heat effect the tweeter?
campbell8402
campbell8402
south carolina
whitedragon551
