What would have more output?
Cameron_B
Single Cab Loud
I have a single cab s10 im looking to put a system in.
I have 1.4~ cubes available for a box, with ~5.5" mounting depth.
Should I do 4 RE 8's ported on 250wrms each.
OR
2 Kicker CVT 12" sealed.
Will the 8's reproduce low frequency better than the kickers?
i had a 93' ranger std cab with 3 re 8"s ported in it in 1 cube tuned to 35 Hz hooked to an infinity 611a (657 watts) and my shix bumped for 8"s...if done right, you will not dissapointed for sure.
just my .02
approx 114 in^2 on the 8's, approx 170 in^2 on the 12s and in theory you pick up 3dB for porting, and 3dbs for doubling cone area so lets do the math
170 is 50% larger than 114 so figure approx a 1.5dB increase in output
porting is porting... 3dB increase in output
so IN THEORY, the ported 8's should be approx 1.5dB louder... negligable
also have to take into account driver sensitivity and power in this case the cvt's are more sensitive
the cvts are rated at 87.1dB so 2 = 90.1 dB
re 8s are rated at 81.2dB so 4 = 87.2 + 3dB for porting = 90.2dB
so in THEORY (can't emphasize this enough as i haven't tested either driver) the 8's will have a slight advantage if you choose to run the 8's at 250 each and the 12s at 400 each
however any way you look at it... its pretty **** close, id go ported 8's for a lower F3
OR
it will come down to the install.... the re will sound better than any kicker, and get louder if the install is done rite.... id pick the 8's...
i dunno how you got ur numbers, but 4 8s have 200 square inches of cone area and 2 12s have 226, i would do the 4 8s ported
Cameron_B
Single Cab Loud
Cameron_B
NC
skmfkr
vegang
vegang
