What wood?
Common recipes;
MDF + veneer, then stain the veneer and top coat {poly, lacquer, etc}
MDF + primer + paint
Oak, birch, maple 7 ply plywood found at the home center. Expensive as the
quality is higher than construction grade plywood, but it has the thin veneer
of either oak, birch, maple on both sides. This veneer is course, unlike the thin
veneer you buy. Course can be good. I prefer the course grain of oak plywood
over oak veneer. You can fix the plywood edges by applying iron on veneer strips
and use a razor blade for a clean look. Stain the wood, then top coat.
You can substitute MDF for particle board if you have great woodworking stills
as you have to understand how to deal with the weaker material.
Exotic:
You can use furniture making techniques on speaker boxes using solid wood, but
it's expensive and it's a more advanced topic with issues.
You can cut a tree and carve it, make a cylinder shaped enclosure and carve
the innards to make air space. lol
You can do fiberglass boxes.
no idea what my furniture is...im thinking maybe just doing bare mdf at first...see how that goes. unless the birch isnt that expesive..What are the cost of some of these things?
Why not build mdf enclosures , then use the 1/4" veneer over top the mdf ? There is a variety of different veneer available . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
3/4" x 4' x 8' sheets;
13 ply baltic, marine plywoods = I've seen up to $300, lol
7 ply oak, birch, maple plywood = ~ $45 - $50 per sheet, lumber yard = may have better quality over home center.
mdf = ~$25 - $35
particle board = ~$20
prices vary from geography, home center vs. lumber yard, etc.
If you choose any plywood, always cherry pick the sheets for low warpage,
and good finish on both sides. Home centers tend to store the wood poorly
and it's warped. Lumber yards may have better storage, less warpage, but cost
more. Lumber yards may have 'A' and 'B' grade where 'A' cost alot more. Do a visual
inspection if you see both types. I usually snag 'B' grade, it's more than good.
Veneer is super thin. You can use 1/4" oak plywood to skin the MDF or particle
board box, but the cost of MDF + 1/4" oak could cost as much as just getting
3/4" oak in the first place and less hassle on construction - no skinning required.
MDF primed, sanded, and then covered with professional grade bedliner such as Line-X can look pretty sharp, IMO...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Depends on what route your going . I would say 45 the edges so you have no exposed end grain would be a good start //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If hes asking the what type of wood question, I'm don't think he has the skill to properly 45 all edges to get rid of end grain (without having lots of putty). But then I could easily be wrong.
I dont have enough skill but i know someone who does:)....And i dont think it should be that hard now that i know what your talking about. I will look into that veneer.
baseballer1100
My life be like....
baseballer1100
Kentucky
ramos
