what wire do i need?
Me personally considering you have a blazer....you will soon be sucked into car audio and will want more system so I would go ahead and run a 1/0 gauge kit so if you do upgrade your amp in the near future then you will already have a good size wire for your amp.
http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0
( Dont include speaker wire,RCA cables ) It also will leave you with about 3-4 ft of 1/0 gauge wire left which even on the site says you can upgrade your stock grounding and ground it to the chasis ground, and maybe adding a run of 1/0 from alt to battery? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And your amp has 2 x 30amp fuses correct?
So I would go with the 60amp fuse to go with it considering you got to pick it yourself with that kit
Hope I was some help:p:
Can't you just get a 250amp since you're already gonna go 1/0AWG?
Dylan
Dylan
Washington
type[s5]
BP1Fanatic
BP1Fanatic
