What way should the subs point?
rhconcepts
OR
I cant tell but I think it sounds better pointing back but will one way over the other give me more db
No not what sounds better. What way do people point them to get the most out of them. In a car trunk everyone points them back, why is that? do they hit harder? Thats what I'm getting at
It's entirely dependent on how much air space there is in your trunk, the distance of your car, etc. If you point it back, what you're basically doing is making the sound waves travel farther before reaching your ear. This means you may need to alter time alignment, and the resonance frequency of your car will be lower so you may get lower bass.
Sub frequencies are omnidirectional. They don't "travel farther" because of how the box is pointed. What you get by pointing them into a confined space like that is an additional loading effect that can enhance the ouptut. Every car and install is different. It's easy enough for you to try both, so do it. Figure out which you like and stick with it.
That is a HUGE box for a pair of W1s, and if you're looking for hte most output, you bought the wrong subs. JLs, W1s especially, are not high output subs.
Yes the box does look big but I went off of JLs design on the website so its 1.75 per sub. And the subs are not staying. Im going to upgrade to w3 or maybe w6. But if I get the w6 I need a new amp. I have a the JL xd600/1 and would have to go get the slash for the w6 so thats a big step up. This is the 3rd box but the 1st ported. I wanted to make a triangular box but I had a hard time working in the port because the port is a L shape.
Meh, test it yourself and if it's the same leave em back so they can't see em through the back window //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
rhconcepts
rhconcepts
Blaine, MN
chillin
