What type of dye to use in fiberglassing?
um. you paint it. fiberglass will NEVER come out smooth\mirror after you create it. you need to sand it, then fill all the dips with bodyfiller, then you need to sand it again, and bodyfill again [several times], then you need to paint it.
its a very labor intesive process that takes alot of work and time.
fiberglass/resin, body filler, sand, body filler, sand, sand, sand, sand ( or something like that).
here is pic of the door panels i just built. you can kind of see the different layers of body filler on the panel. kind of looks like the rings on a tree. once you finish sanding you prime your project with some high build sandable primer a few times to get any imperfections out and then paint it.
there is a kind of pigmentation that you add to the final coat with clear resin. it comes in diffrent colors. i forgot what site is it that sells it, but im sure. google will find it.
laters
It can, but in the one off deal we work with in car audio it's not worth it. You can actually make molds and cast perfect parts from them that don't require filler at all. This is the way boat hulls are built. The exterior we see is actually gel coat sprayed into the mold before the glass is laid. Pop it out of the mold and it's perfect no filling required. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
there is a kind of pigmentation that you add to the final coat with clear resin. it comes in diffrent colors. i forgot what site is it that sells it, but im sure. google will find it.laters
Yep something like this. But unless your casting from molds, it's a waste of money. After you add filler and what not you won't see it anymore. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://www.fibreglast.com/showproducts-category-Pigments%20&%20Glitterflakes-94.html
amartin_72
Banned
amartin_72
Madison , WI
ramos
