What type of amp would be best that costs least?
Yitzy
ph3@r
113
MA
I am planning on buying 2 JL W3 12 inch subs and placing them both in one sealed box. What amp should I buy (up to $300) to power these? If possible name the actual product thx a lot //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
What Voice Coil Configuration means is what each Voice coil's impedence (ohms) measures at. Are your subs dual 2 ohm, dual 4 ohm, dual 6 ohm???
The final impedence after wiring the coils and subs together will help determine the better amplifier choices.
Take it easy,
-zane
The JL W3's that I am lookin at have a 6 ohm dual voice coil! If its better to get a lower one tell me. What should I do differently because of the 6 ohm DVC?
Talk to your local car audio dealer, he knows how to hook them up to get you a 3 ohm load. This is just fine for practically all amps out there. If you can only spend $300, I suggest a JBL amp, maybe a 600.1 amp for them?? I don't know much about the JBL amps, but I am pretty sure there is a 600.1 amp that will get you about 225 wRMS for each sub when wired at 3 ohms.
well I am new to car audio (my first system) and I just want everything to work to its capacity. Thx for the advice I will check it all out with an expert. Hopefully I will find the right equipment!
Yitzy
ph3@r
Yitzy
MA
firemx220
randy hagan
    Jul 15, 2026
