sportyaccordy
Here's what I have planned:
- Seal up the front w/Dynamatish material
- Fill the back w/the paper egg cartons (can I use the styrofoam ones though? They're easier to find)
- Cover my 1" spacer w/clay, let it harden (hair dryer maybe?)
Here are the important specs on my midbasses:
*Frequency range: 35-5,000 Hz
*Fs: 55 Hz
*SPL: 90 dB 2.83V/1m
*Vas: .50 cu. ft.
* Qts: .71
*Xmax: 2.5 mm
Are these (namely the Qts) good specs for a free air setup? They'll be run up to about 2.5KHz, but they won't be highpassed at all...I want maximum low frequency extension from these (i.e. BOSE systems...even the fronts reach low into the freq. range, as much as they "****") as I don't want a sub and my 6x9 rears are maxxed out bass wise. I might highpass everything at ~30-35Hz though to keep it safe. What else can I do to get the most bass from my insides?
*Fs: 55 Hz
*Vas: .50 cu. ft.
* Qts: .71
*Xmax: 2.5 mm
