What to Cover Previous Ground Holes With?
Pretty simple question. In previous amplifier installs, I've left a few holes in the frame of my car from the old ground points. What do you guys reccomend to cover these for both ascetics and to protect the frame from rust?
mine was all hidden under trim, but i used ac duct tape, the silver kind. cleaned up the area and laid it over it, its watertight
google body plugs.that what i would use.
if you want cheap then do what mitch said.
or if your really ****, weld them shut...
or use deadener .
Googling "body plugs" might come up with different search results //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
ya right.. lol
---------- Post added at 08:41 PM ---------- Previous post was at 08:40 PM ----------
Personally Id probably weld them. How big are they and where are they at?
ya me to.
i dont like covering up holes with anything.
i weld them.
Seam sealer alone, if the hole is no biger than a 1/4". Or, with a piece of thin gauge metal about the size of a quarter, depending on the size of the hole. When the seam sealer dries it will hold it tight. You will either have to cover your plug entirely with the sealer or paint the finished product to keep it from rusting.
just paint the **** with rustoleum and cover it with some quality tape and deadener. i dont think a welder is a common thing.. as much as i want one
i suggest you get to baking then. I dont remember allowing you out of the kitchen anyway.
B1GR3DDD
B1GR3DDD
Delaware
adulbrich
