hispls
They are all the same from first to newest runs.
Depending on where your vehicle peaks the fresher sub may be noticeably louder around the typical vehicle peak frequencies. The response is going to shift downward as the suspension breaks in -- in the case of the VVX the Fs gets very low. I wouldn't expect the kind of difference you are describing, though.
Most likely it has something to do with the connections or how well the woofer was seated to the box. It's not 100% applicable but in our single 8" woofer testing we gained over a dB by trimming the speaker wires to fit better in the terminals and variance in screw tightness has changed it nearly a dB as well.
That's a super easy way to find 2db!
