What Subwoofer and Amplifier would work best for me and this enclosure?
jshep105
USA
Hello. I bought a Single 12" Ported Subwoofer Truck Enclosure and need to find a good subwoofer and amplifier for it. I am new to this hobby and need help on finding a good match. Here are the specs of the box:
Kicker Loaded Truck Enclosure
Subwoofer Box Features:
Single 12" Truck Sub Box
Mounting Depth: 5-1/16"
Air Space: 0.80 Cubic Feet
Ported Enclosure
Dimensions: Width 20" x Height 15" x Top Depth 5" x Bottom Depth 7-1/2"
Designed to fit behind the seat of most trucks
Constructed with High Quality MDF
High Quality Binding Terminal Cup (Accepts Banana Terminal Plugs OR Bare Wire 'up to 10GA')
High Quality Gray Carpet
Thanks in advance
usually, it's the other way around. You don't buy a sub for your box, you buy/build a box for your sub.
....and 0.80 cubic feet seems awfully small for a 12" ported setup.
All I gotta say is GOOD LUCK! A friend of mine was GIVEN one of those single 12" Kicker Truck enclosures loaded with a cvr & it sounded like absolute garbage :-( With the limited mounting depth & space you have, it's really pointless to even try and find something that will work with that. I ended up building a custom box for my buddy - He has a regular cab F-250 so I made him a box that fits behind the seat housing 1 - 12" Pioneer Champ Pro (An older 1 that looks like a pro but it's not ;-) -6.5" mount depth) It's ported to the tune of about 36 hz, port up, pass side exit, sub on driver's side behind the seat 1.9 cu ft. net - I sold him the sub for $40, and it cost me about $40 to build the box - The sound difference is NO COMPARISON - Build yourself a proper enclosure for whatever sub you decide you want to run
Okay haha change of plans then. What if I got a Atrend E12Sv B Box Series 12-Inch Single Vented Subwoofer Enclosure
E12SV 12" Single Vented
Width 16.62
Depth 17.5
Height 14
Vent Width 1.25
Vent Height 12
Vent Length 24
Vent Dim 15
Hz (Tuning Frequency) 33
Gross Cu. Ft. 1.7
Net Cu. Ft. 1.25
And I was thinking either a Pioneer TS-W3002D2 Subwoofer or a Rockford Fosgate P3D2-12 Subwoofer.
And finally powered by a Rockford Fosgate R500-1D Prime 500 Watt Mono D-class Amplifer.
Please give me your suggestions on what to do. I listen to mostly rap and hip hop. The box will be going on a trunk of a 2002 Grand Prix. Thanks again
I can't say I would buy that enclosure either, if you insist on buying a pre-made box at least go with something better than Atrend... With that power I'd say P3 - Get the D4 and wire it to 2 ohms on the R500
Spend a little bit more and have double07, dbeez, prorabbit, or someone on this forum build & ship a box to you. A Basic enclosure for a single sub with shipping is not as bad price wise as you would think... Look into it, it will be the best thing you do and well worth every penny
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Shallow mount subs like those recommended are a favorite of truck owners. Typically the space under the seat is wide but “shallow” from bottom of...
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
jshep105
jshep105
USA
h2h0e
    May 20, 2024
    May 20, 2024
