What subs work well in 4th order boxes?
lulz
Like said before, sealed box woofers work well in 4th orders...you can make almost anything work with the right alignment, but a high qts/low fs woofer is best in most cases.
Because I'm not super familiar with what an actual high qts or low fs number would be, can you say what range I should look for? Example: qts higher than xx and fs lower than xx...
I'd say qts at .5 or higher is optimal, fs should be 30hz or lower in most cases. The Mach 5 IXL made for sealed boxes looks like a good candidate, as does the high qts version of the Fi Q.
Perfect! Thanks....Now I just need to find a lot of brands that fit that and read reviews!
Oldbass38
I'm going deaf
Oldbass38
Atlanta, GA
Oldbass38
AJ (ACE)
    Jun 28, 2026
