Hi guys,
So I've been having a nightmare trying to sort out the sound system in my car. My basic setup is a Vibe Black Air b12 1800w sub with built in amp, with vibe black air 4s in both front and back standard speaker fittings. I have recently bought a (you guessed it!) Vibe Stereo 4 1200w Amp which is currently powering my speakers.
However, when I turn the volume up high, the Amp cuts out and the 'protected' light comes on. I was told it was something to do with the Earth? I currently have it earthed to the brake light earth (which works fine on my sub, on the other side). I have sanded off any paint to expose bare metal but this still didn't help. So I took out the back seat and put the earth to some bare metal, but this didn't do anything at all.
So I am beginning to think it is the power cable, or the lack of power. I had a 4awg fused cable running from the battery to a splitter in the boot, which then became 2 x 8awg cables, one for the sub's amp, and one for the speaker's amp.
By process of elimination, I'm guessing that not enough power can travel down these 8 awg cables when I crank the volume, resulting in the amp cutting out (although the sub has never cut out). So I have bought another 4awg cable to run the amp on its own (however, when i connect the 4awg power cable straight into the amp, it still cuts out at higher volumes).
My problem is that I don't know what size fuse to put on this new 4 awg cable to stop my amp from frying... I figured it was something to do with the power consumption of the amp but I'm not too sure.
Any help or other suggestions would be greatly appreciated... I've managed to blow the splitting terminal today resulting in just speakers or just sub, which isn't ideal.
Thanks in advance
Thanks in advance
