what size box do i build?
  • 1
analogkid
Banned
1,325
n.y.
i have a soundstream spl160 laying around and i figured id build a ported enclosure for it. the manual lists 2 different sizes: 1 is 3.0 cu-ft @27 hz (2- 4"x 22" ports) 2 is 4 cu-ft@32hz (3- 4"x 16" ports)
i really have two questions. they dont make mention of the ports being round or square so i thought i might build a slot port box. will this work just as well?
the other question is which of the two sizes do i use? i would like the best sq possible from it. i figure a ported 15 will give some good bump anyway. i drive an 87 4runner its a relatively small suv. i will be feeding the sub 800rms @2ohms.
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
analogkid
Banned
analogkid
n.y.
analogkid
    May 20, 2024
    May 20, 2024
