V vroomy 10+ year member Senior VIP Member 200 1 Australia Feb 21, 2011 #1 hey is there any sub box guru's out there that can tell me what size Aeroport (or any pipe style port) this will work out to? - 154.83cm2 X 27.58cm long.... thanks for any help Click to read more...
RAM_Designs 5,000+ posts SketchUp Master 21,735 362 Rockwall, TX Feb 21, 2011 #2 Where'd you get those measurements from? 154cm^2 equals roughly the same area as a 5.5" circular port.
RAM_Designs 5,000+ posts SketchUp Master 21,735 362 Rockwall, TX Feb 21, 2011 #3 And 27.58cm equals roughly 10.875".
OP V vroomy 10+ year member Senior VIP Member 200 1 Australia Feb 21, 2011 Thread Starter #4 being that i probably wont find a 5.5" tube is there any way of making it a 4" or 5" and just longer or shorter to compensate?
SpeedEuphoria 10+ year member CarAudio.com Elite 578 8 BCM Feb 21, 2011 #5 what size box? you may be best with a 6" aero if your not doing true aero w/ flared ends your going to need larger pipe as the flares make it much more efficient
OP V vroomy 10+ year member Senior VIP Member 200 1 Australia Feb 21, 2011 Thread Starter #6 would i be best off making a rectangular port then? and if so any you guys know what lengths the sides need to be to get that area?
Phoenix Risen 10+ year member OG.... Original Ginger 4,160 103 Dayton/Springfield, Ohio Feb 21, 2011 #7 to get the sides for the port figure out what you want the longer side to be usually the length of 1 dim of the box. and divide the area by that that will give you your answer
