what single din ? 80 prs or what else ?
brian84corvette
i need a headunit like crazy bad
acutally been needing one for quite some time
but im a stubborn heard head that hates learning all the little intricate details of new fangled electronics and software -
but
its time i pony up and get something good - id like to buy the right headunit the first time.
my intended viechle = 1990 chevy suburban demo machine and daily driver. 4th order wall with six 18s on a ddm3a + a pair of 4 chans to run active my front stage ( super tweeters / two 6.5 each door / pair of 8" midbass and pair of 12" electric guitar speakers
410 amp hours battery reserve and singer 320 hairpin alt / 1/0 royal exelence welding wire thru out
so realisticly - id like to have a headunit that has good rca voltage so i dont have to mess with any external crossover / line driver junk. i just took out my current line driver as it was introducing ground noise whine to my system //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
anyhow thats my ride. its just brutal loud to sit in - and now i need to buy a headunit for it cause im tired of my janky crossover hooked to my i phone. my gear is too nice to run this ghetto.
so
what headunit should i get ? single din please = no touch screens or dvd crap nessary ... i want my headunits function to play music mostly from my i pod or i phone or maby i can try the usb memory stick thing... that seems nice too
o also i guess there will be no speakers hooked up directly to the headunit. i have no need for any speakers under 20w rms lol i dont kno if that makes a diffrence or not haha
clarion cz702 5 volts preout and better sound quality then the 80prs
The 80 has 3 24 but DACs, left right independent EQ.
What makes the Clarion better? Is it because you have one on stock speakers?
---------- Post added at 10:49 PM ---------- Previous post was at 10:49 PM ----------
was this a direct swap or how did you come to this conclusion?
Dude wouldn't know what to do with a 80
im not spending 1000 on a headunit lol
im a ghetto blaster
ground pounder loud
but i still enjoy some quality to my sound. id be comftorble and still eat and pay my bills if i spend 250$ ish on a headunit as my max
kenwood x998 is a good choice, clarion cz 702 is the cheaper choice. Pretty sure the alpine 149bt is not active capable but its a very good head unit still. You can also find used 80 prs for that budget. I got mines used and its working great.
I have tried both using stock speakers & aftermarket on external amp.
Out the box clarion had the better sound. In the end 80prs sounded the best after tons of tuning.
what limits the clarion is the slopes.
The 80 has 3 24 but DACs, left right independent EQ. What makes the Clarion better? Is it because you have one on stock speakers?
I didnt say clarion was better, i just said the sound quality is better without going into specifics.
If you know how to tune your eq then the 80prs is best, but the main thing about the clarion to the pioneer is the fact that you can get near identical quality if both tuned correctly, but the 80prs will always have the pico fuse issue.
This is why i changed to clarion from my 80prs, i just disconnected my battery properly and when i connected it back my 80prs blew the pico fuse.
818
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
526
brian84corvette
brian84corvette
coral springs FL.
LosIsATool
    May 20, 2024
    May 20, 2024
