What should i wire it to?
shalizi
i got those 3 10w6 ae editions with a soid audio f2000 amp...and i also still have my 12w7..i want to use the amp to test both systems to see which i like more...how many ohms do i run for each....
amps specs
500x2ch @ 2 ohm
300x2ch @ 4 ohm
1000x1ch @ 4 ohm
1000x2ch @ 2ohm
ok i know for the w6 i wire at 4 ohms i know this is a noob as question but on the amp there is + - + - for the sub wires... and it says bridge + . . - so how do i get the 1000x1 chan @ 4 ohM??
By bridging the two channels into a single, stronger output.
Wire the positive output on the left channel to the positive input for the sub(s) and the negative output from the right channel to the negative input for the sub(s).
shalizi
shalizi
Los Angeles, Ca
shalizi
