what ohm load..rd 1750.1
Good electrical?
If you have a very solid electrical, I would venture to try that amp at .25 for a burp. It's a push, but still
Daily it will take .5 all day, and expect a fairly large deal over 2k, it'll do about 1800, from what I understand, at 1ohm
Heres the break down of power testing:
1 amp, single 1000ca everstart maxx, 1 Eagle Picher 12a5000, factory alt
4 ohm nominal = 520 watts @ 88% efficiency (voltage fell from 14.3v, to 14.1v)
2 ohm nominal = 960 watts @ 84% efficiency (voltage fell from 14.3v, to 13.7v)
1 ohm nominal = 1635 watts @ 75% efficiency (voltage fell from 14.3v, to 12.8 volts
.5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v)
.35 ohm nominal = 2245 watts @ 65% efficiency (voltage fell from 14.3v, to 12.8v)
So depending on what his rise is, 1800-1900 watts when wired to .5ohm
And as i said, id easily run them at .5 daily.....not on all factory, but urs seems to be enough for it
Sundown 1500:
RD 1750:
How much did u get the RD for?
schrummy
schrummy
Ames, Iowa
snoopysnooper
