large mechanical stroke = high displacement.High sensitivity + high thermal power rating + large cone area x large mechanical stroke = high displacement. Backed by an appropriate and well executed enclosure + slightly more power than you need + a steady voltage supply to the amplifier so the power supply doesn't starve and die.
I know, it has holes. But I don't do SPL. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
depends on your sub. build an enclosure that is to spec for your sub. as for round vs slot, i have found that if you build it properly and dont have a lot of sharp corners, they have been about the same for melarge mechanical stroke = high displacement.
does this mean xmax? also can someone talk a little about how to properly execute ported enclosures. how much port, how u know how much and also round v. slot ports
when i use calculators on 12volt.com round ports tend to require much less space as well as less work. is this correct or am i mistaken?depends on your sub. build an enclosure that is to spec for your sub. as for round vs slot, i have found that if you build it properly and dont have a lot of sharp corners, they have been about the same for me
umm......//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif i dont think hes joking haha:wow:come on man at least tell ppl ur kidding
Maximum total displacement is cone area x Xmech. Xmech is the maximum physical travel the soft parts will allow, while Xmax is the linear stroke the motor provides before losing more than 30% of the BL product. They can be very close figures as well as very dynamic.large mechanical stroke = high displacement.
yeah but you have to be careful b/c if not done correctly round ports can get loud port noisewhen i use calculators on 12volt.com round ports tend to require much less space as well as less work. is this correct or am i mistaken?thanks
