Quote:
"A few points :
- yes, in general you're looking for a rather high Qts sub for Infinite Baffle use, because you get no "Q enhancement" from an enclosure. However, a low-Q sub can also do well IB, if the resonsant frequency (Fs) is also low. As an extreme example ... if the Fs of the sub is 10Hz (none that I know of, just an extreme to illustrate a point), does it really matter what the Q is? The response will be quite flat down to 20kHz in any case.
- If you have some EQ at your disposal, including possibly a Linkwitz Transform, and a relatively healthy xmax ... you can pretty much "dial-in" the response you want.
- Rememeber that power requirements to reach full excursion will be less for IB. There's really nothing to be concluded from the fact that subs in small enclosures can "handle" more power, other than the fact that smaller enclosures are less efficient.
- Aperiodic enclosures are not the same as Infinite Baffle, except in a limiting case. AP means you've really got two enclosures for the sub, separated by a resistive membrane. The enclosure closest to the driver is quite small, and the other enclosure is quite large ... perhaps "infinitely" so The resistive membrane gives you some "tuning" flexibility. In one extreme, the acoustic resitance is so high (thick, dense) that you really only have the very small enclosure, right near the sub. In the other limiting case, the acoustic resistance is so small (thin, light) that the two enclosures are very tightly coupled, meaning that you're practically running IB (if the second enclosure is huge ... remember, IB is identical in all respects to a very, VERY large enclosure)."
http://forum.elitecaraudio.com/showthread.php?threadid=127544&pagenumber=2
Here's a concrete example to demonstrate my point ... the point being that a low Qts can be very acceptable in an IB alignment, providing that the Fs is also low. Consider the Image Dynamics IDMAX, specs found here (D2 and D4):
http://www.imagedynamicsusa.com/tech_page.php?name=IDMAX12D2%20V.3&type=sub&id=idmax
http://www.imagedynamicsusa.com/tech_page.php?name=IDMAX12D4%20V.3&type=sub&id=idmax
Qts on the order of 0.34~0.35 (which would seem pretty "borderline", if not downright too low, for IB), but the Fs is about 20Hz. And ain't nobody complaining about DEEP bass from IDMAX drivers in IB mounts
So I'm thinking a better "Figue of Merit" might be Qts/Fs, or something along those lines ...
