what kind of wood should i use? and can my amp handel another sub.
strawhat
ok so im going to make a box cause i might be getting another sub and my box is utter poop damaged from my car accident. so i would have to of these subs,
10" Champion Series Car Subwoofer
Peak: 1000 watts
RMS: 200 watts
Impedance: 4 Ohms
Sensitivity: 95 dB
Frequency Response: 20-180 Hz
Single Voice Coil
Injection-molded polypropylene and paper composite cone
Urethane surround
Double cone design with reinforcement nodes
Nomex® spider
Projected pole yoke with vented pole
6 Layer, long copper voice coil
32oz. Strontium magnet structure
Stamped basket with magnet cover
Integrated single-sided spring compression terminals
and my amp can handel this.
Audio System
Sound Output Mode Stereo
Response Bandwidth 5 - 50000 Hz
Signal-To-Noise Ratio 100.0 dB
Max Output Power / Channel Qty 200 Watts x 2
Continuous Power / Channel Qty 100 Watts x 2
Input Channel Qty 2.0
Output Channel Qty 2.0
High Level Inputs Yes
Input Signal Voltage 0.2 - 5V
Crossover Channel Qty 2
Crossover Slope 12.0 dB/octave
Low Pass Frequencies 80 Hz
Amplifier Output Details 150.0 Watt - 2.0 Ohm - 20 - 20000 Hz - THD 0.8 % - 14.4V DC - 2.0 channel(s) , 100.0 Watt - 4.0 Ohm - THD 0.08 % - 14.4V DC - 2.0 channel(s) , 300.0 Watt - 4.0 Ohm - THD 0.8 % - 14.4V DC - 1.0 channel(s)
Soft Start / Quiet Turn-On Yes
Additional Features Gold plated connectors
so cant that amp handle 2 of thoes subs and would it sound better then the one sub i have now bridged(the sub i have now is the same as above.)
and what type of wood should i make the box out of.
Is audio system the name of your amp?
Your amp is only rated for 4 ohms bridged
If you run 2 subs they would need to be 8 ohms or 2 ohms each.
I would seriously considering upgrading your equipment.
There is some cheap stuff for sale on this board that is MUCH MUCH better than what you have.
I use 3/4" MDF for enclosures.
Agreed, much nicer gear in the classifieds section. start with a mono lock sub amp, then you can run two 4 ohms subs, but the subs should be equal.
No, you cannot have another 4 ohm sub on that amp.
strawhat
strawhat
Center Conway, NH
keep_hope_alive
