What kind and or size amps. HELP!!
krj725
**Brand New Kicker DC124 Dual 12" Loaded Vented Comp C12 Subwoofer Box **Dual 12" Vented Enclosure with Kicker Comp Subwoofers **4 Ohm Final Impedance **Peak Power Handling: 600 watts **RMS Power Handling: 300 watts **Oversized ports with flared ends for efficient air flow and no noise **3/4" MDF Construction **Heavy duty black carpet covering **Embroidered Kicker logo **Dimensions: 32-3/8" W x 16" H x 17-3/8" D (Bottom) x 13-15/16" D (Top)
or
**·Brand New Kicker DCVR124 Dual 12" **·CompVR Loaded Vented Enclosure **·Dual 12" Vented Enclosure with CompVR Subwoofers **·4 Ohm Final Impedance **·Peak Power Handling: 1600 watts **·RMS Power Handling: 800 watts **·Oversized ports with flared ends for efficient air flow and no noise **·3/4" MDF Construction **·Heavy duty black carpet covering **·Embroidered Kicker logo **·Dimensions: 32-3/8" W x 16" H x 17-3/8" D (Bottom) x 13-15/16" D (Top)
1st you would need an amp that does 600 @ 1 or 4 ohms, if you get 2 subs.2nd you would need an amp that does 800 @ 1 or 4 ohms, if you get 2 subs
Pyramid "CRYSTAL" 2 Channel 600 Watt Amplifier
Details:
·Variable Bass Boost ·Variable Input Level ·Remote Turn 0n/Off ·Gold Plated RCA Inputs ·High Level Molex Inputs ·Power on LED ·LED Protection Indicator ·THD
would this work for the 600
and this for the other one
**800 WATTS, 2 CHANELS BRIDGEABLE POWER AMPLIFIER **Max Power: 800 Watts **RMS Power Output 4 Ohm: 80 W x 2 **RMS Power Output 2 Ohm: 150 W x 2 **RMS Bridge Output 4 Ohm: 250 W x 1 **Input Impedance: 22k Ohm **Input Sensitivity: 200m V~8V T.H.D.:
krj725
krj725
Boston
krj725
