What Is Wrong
dennisthamenace
Ok my sub keeps turning off and on....... power light on the amp is always lit, but the problem is is that the sub turns off, i spent 15 minutes just watching it and every now and then it will move up and down once,but its a slow movement, not like a hit or anything. My sub has been turning off and on now for a few days.. now im wondering if this is the amp or electical.... still yet to check my rca cables on my headunit.
ok i turn up the volume and it only starts moving when the volume is like 10 clicks before distortion kicks in, its like theres like not enough power being sent to it, like it just doesnt have enough to be hitting the notes, the sub just moves up and down. and when i turn my car on the sub moves even more..
ok the sub started playing again, but the volume is fluctuating, like its loud one second then noticably quiet the next. Would this mean its most definitly a power or wire problem? or what the amp maybe not giving steady power?
did u try checking the voltage at the amp, and the voltage at the battery? maybe bad connections along the way.
does this cancel out there being a loose rca cable? and leaves it to power and wire? i think i need to buy a voltmeter then, but i made sure all the power connections are securly where they are sopposed to be.
dennisthamenace
dennisthamenace
shoreline,WA
dennisthamenace
