what is wrong with this tweeter
I believe the problem is the 5KHz crossover that the link says it has, the crossover point may be higher than most vocals. You will need to remove the crossover and use a different means to stop frequencies below what the speaker can handle from getting to it.
ok well maybe it could be because also i have 2 sets of components 2 6x9s and that tweeter all on the same amp. i measured it it comes to a 1ohm load. and there is enough power.. i took off that crossover capacitor and it still does what its doing im pissed. i also have the amps crossover all the way up and the high pass filter on. but every noise comes out of the 6x9s and the components i guess this tweeter was a waste of 50... it does make the whole system sound better but it doesnt seem like it makes any of the highs louder like i wanted cause the bass over takes me highs so.. this ***** im pissed what a ****** tweeter
im an idiot i should of just got this
http://www.audioque.com/AQ-ST1-SuperTweeter-Sold-As-Pair-_p_104.html
but i cant go into detail i just needed to waste money fast so i bought that mtx thing damnit
i also assumed since it was $50 you get 2 of them i mean no one should ever support this thing it should be boycotted
can i ask you why its louder without that tweeter involved . my amp is supose to put out 300rmsx2 @ 1ohm so there is enough power. and yea.. i think i do need more than comps and 6x9s can someone tell me how to get it louder ... i guess you just use really good tweeters right. wait maybe that tweeeter is ******* up all the power because this one site says it can handle 300 watts rms . so that does not leave enough power for my other speakers ****. thats why... i should of got lower power tweeters it would of been way better..also my amp can hanldle putting a bunch of **** on it.. its a crossfire .. hfc 30
Hooking multiple speakers on the amp that are not the same causes a ton of problems, each speaker need different frequencies.
To get a really loud front stage, most people choose to move to a pretty simple active set-up using PA Midranges and Super-Tweeters. I do not know anything about your amp at all, so i can't really make any suggestions, but in my walled-off ranger I'll be running 2 8 Inch Sundown Neo-Pros and a Crescendo FT-1 in each door, using a pair of matching 2 channel amps, running 100W each to the Tweets and ~200 to each pair of midranges.
zxcvb134
zxcvb134
pittsburgh PA
UnderFire
vegang
vegang
