what is the Hi level input 1 & 2?
standard85
FL
I have kicker amps a few for subs and 1 for hi's and mids. I was wondering what the Hi level input plugs are on the amps, the amps come with a plug with split ends that is specifically for the Hi level inputs, The mid and hi's amp is a 4 channel amp and has Hi input 1 & 2, if any 1 has a explanation for these I would appreciate it, thanks.
if you are talking about the plug with the white and gray wires (and purple and green if it is a 4ch.) those are for seding signal to the amp via high level input rather than low level input. Instead of using rca's you conect that plug into the speaker wire of the matching colors for the signal to your amp.
standard85
standard85
FL
5.3bowtie
