What is the best sub?
I'm guessing the last few didn't even read the original post... I don't usually see those subs suggested for 250W @ 4-ohms... or at least not on CA.com, anyways. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Apperantly, everyone seemed to forget that you'll be installing this in a boat which means you should be looking at a sub that performs well in a vented enclosure.
The bass will be louder in an open area such as a boat and vented enclosures are much more efficient than sealed ones allowing you more dB off of 250w.
Also, the fact that you want to run @ 4ohms means your amp shouldn't sacrifice much of its damping meaning greater control of the sub at sub 30hz frequencies.
I would look into any sub that
a. Is designed for a ported/vented enclosure
b. Is made of weather resistant materials (no paper or foam)
To be honest, because of space requirements, I would seriously look into a BT1214 from Bazooka.
im looking to seal the sub, want more of an sq set up.
Ill have it in a little storage area with minimal moisture so im goin to build the sealed box and fiberglass it. I'm also looking to make sure the sub has a rubber surround so theres no corrosion.
but thanks guys to all the suggestions, im not the most familiar with the audio market.
BumpMW
BumpMW
Annapolis MD
2Kaccord
AJ (ACE)
    Jun 28, 2026
