What htz to run sub at?
Photonfanatic
TX
I am getting a sundown audio SA-8. The manufacturer's website says the sub will run 34.6 Htz. I'd like to run it at 35 htz, IF that is advisable. Is it usually a good idea to run a sub right where its rated at? Or do most people give it like a 5 htz bump just to be safe? I'd like to run it as low as I can I guess. I don't want to miss out on anything after all.
What rating are you looking at that says "it will run 34.6 hz"? I think you're not understanding something.
So generally, people run their subs right at the Htz rating stated by the manufacturers, correct? There isn't some well known fact of giving them 5htz over the recommended specs, or something? Just wanted to make sure before I port my box.
What do you mean by "port my box"? A proper ported subwoofer enclosure will meet specifications that work for your specific subwoofer as well as the type of sound you want to achieve. Since you clearly don't know what you're doing, please look to one of the vendors to get you a proper box design.
Which vendor would you recommend? I'd be happy to take any recommendations on a good box builder who will build a box and ship it to me.
And a semi related question: What are going to be the dimensions (in inches) of a ported box for the sundown Audio SA-8? Just one sub. If I build the box at the max of .75 cubic feet then that translates to 1296 cubic inches. But I'm not sure how tall and how wide that's going to be.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
Photonfanatic
Photonfanatic
TX
Photonfanatic
    May 16, 2024
    May 16, 2024
