What HDTV do you use?
CRT is a great choice if you don't mind the size/weight.
did you calibrate your LCD? the picture right out of the box is generally not the best. it takes some fine tuning sometimes.
is it hooked up to an HD source?
Its hooked up to comcast hd. I have been tuning it a lot. Picture looks great but sometimes it gets grainy. Its a cheap westinghouse, lol. I got it from best buy but I will be taking it back because friday they have panasonic 42" plasmas on sale for 999.00.
i used to have a 32" sony sdtv
now a 60" sony xbr1
sd channels look worst but hd are better then my 32" sd channels since it didnt except hd signals
but hd-dvd omfg!!!
i would only trade my tv for the pioneer elite 50" 1080p plasmas wich is 7,999
or a sony pearl front projector
If you have comcast make sure you are using components to get your signal. My comcast box has an analog and component output. I switch to the component when I run HD channels and leave it at analog while I run normal channels, the lower normal channels look really bad when I utilize the box using the component which is why they have the option for both.
If your box does not have both call them and tell them your reception through the component cable sucks and you want a dual output one with analog too.
I am running last years Mitsu 52" DLP BTW
Well I waited in line at best buy and snagged a Panasonic TH-42PX60U plasma. The HD looks great but the Sd could look better. I did hook up analog from my comcast box and it does look better. It looks good enough being I dont watch much SD. The dvd looks great also. I think it was a good deal for 999.00. By the way this set is in my bedroom. I have a 50" older mits in the living room, now I hate to watch it. Guess I am going to have to buck up for a new one.
^^ and the quality differences for SD through the composite vs. component output is going to depend on the quality of the upconverter of the box vs. the upconverter of the television
some cable boxes probably have great quality outputs with all definitions, and most boxes probably have defeatable upconverters, so you can utilize the same outputs, whether it be hdmi or component for all channels SD and HD with or without internal upconversion. this, of course, would require reading the users manual, however, which escapes most people
99StangGt
99StangGt
Oregon
Scoobydoo
