what happen to sub
check your remote connection to the amp. It may be lose or pinched. Pinched remote wires will turn the amp off especially if you are driving and hit a bump, etc.
none of the wire insulation should ever be inserted in the terminal.
so what could happen to the sub i push it down and everything and it was fine. all I did was turn up the volume on my deck and the sub turn off. the sub btw did go back on for a sec while I was turning the car
if your amp is getting power and all connections are secured, you have a blown sub. Push down on it and see if it goes down easy with a gentle push, don't push to hard. Nothing will happen
didn't really understand your question above this one, were you bumping it loud before it blew?
rca's come to mind here as well?
Sounds like a possible dead amp. If you have a DMM, play some music and check to see if there's any volts coming out of the amp.
yea i push down the sub down. it didn't go down much tho. i had to push it a little bit hard in order for it to go down.. i don't always play my subs loud tho, but the thing is that im not over powering the sub
miniaznkid
miniaznkid
San Francisco,CA
miniaznkid
vegang
vegang
