What gauge speaker wire... noob question
Nico Koutouzis
I am going to be running 2 alpine type r comps and 2 alpine typr r coaxes... 125w rms for each speaker from an mb quart onx 4.125
Also I am going to be running two alpine type r subs 10" at 1000 w rms at 1 ohm off an mb quart 0nx 1000.1 D
I am thinking 14 gauge for speakers and 12 for subs? Or can I just use 14 all around? (cheaper).
I was looking at this wire
CADENCE 14 GAUGE 100 FEET BLUE SPEAKER WIRE SPOOL | eBay
any other opinions on wire around the same price range... 20$ is much thanked.
I use this stuff in budget installs, it's good quality wire, the jacket is a little thin though.
14 GAUGE SPEAKER WIRE 50 FT CLEAR CASING HIGH CURRENT | eBay
I've bought from the guy quite a few times, great seller.
It's a bit more expensive, but 50 feet should be enough.
I always use 12 gauge for the subs, I use the more expensive stuff because it doesn't take much, around 1700w is when I start using 10ga.
Around 15 feet of this should be enough if your amp isn't far from your box.
Knukonceptz product detail for KLEAR KABLE BLUE 12 GAUGE SPEAKER WIRE
So I should definately go with 12 for the subs. ok and is speaker wire the same no matter the company as long as it is real 12-14 and OFC? should I just buy the generic stuff?
The speaker wire I linked you is OFC, barely rated, it's audiopipe, not a big name, that's why it's cheap.
I personally prefer to use Monster audio 12 and 16 gauge, but it's spendy, about 23$ for 50 feet of 16 and 20$ for 18 feet of 12.
No matter what you should get OFC (Actual Copper). and I believe Cadence makes CCA (Copper over aluminum)
ok... one more thing. I am going to get 10 feet of the 12 gauge for the subs cause the box is literally 2-3 feet from the amp if not less. so I am getting the knu for the subs, but does anyone else have anymore reviews of 14 gauge wiring?
Nico Koutouzis
Nico Koutouzis
Hartford, CT
Nico Koutouzis
