qtipextra
The Original
What else could cause DC out to my subs?
I have checked everything that you can see a black mark on in this high res pic. That would be ALL the transistors, both regular power and the ouput ones too. Thats all the bigger capacitors, and all the big resistors (5W). None of them were bad.
What else?
Heres a High Res Pic:
One thing I should add, the amp doesnt go into protect, it just stays on, and giving my subs DC.
The more power I give to my subs, you can see the sub move out, but it is also moving back and forth at 40hz (the test tone I was playing to test). Then if I swap the polarities to the subs, the obvious happens, the cone moves in, but still resonates at 40hz, but with the cone offset moved in because of the DC.
I can fix it myself, I just need help finding out which componets are bad.
What else?
