What Does Volts Pre Out Mean??
Pre-out voltage refers to how strong the signal is on the Hu's rca connections. Higher voltage allows you to run your amp's gains lower - which will reduce the chance of getting signal noise to the speakers.
well what kind of amp do you have? if your 4 channel is bridgable at 2 ohm's then u can run each comp to the amp using 2channels a peice..meaning you wont be able to run your rear speakers on the amp..if u want to use th rears do it off the h/u...
amp is ALPINES MRV-F540
# 150W x 4 (Max)
# 200W x 2 RMS [4Ohm Bridged @ 14.4V (0.3% THD)]
# 100W x 4 RMS [2Ohm @ 14.4V (0.3% THD)]
# 80W x 4 RMS [4Ohm @ 14.4V (0.08% THD)]
# 140W x 2 RMS [4Ohm Bridged @ 12V (0.3% THD)]
# 70W x 4 RMS [2Ohm @ 12V (0.3%THD)]
# 50W x 4 RMS [4Ohm @ 12V (0.08% THD)]
# Bass Engine
# HP/LP/BP Adjustable Crossover
# One Side Terminal Layout
# Top Mounted Controls
# Control Panel Cover
# Alpine V12 PWM MOSFET Power Supply
# 4 Volt Input Capability
if you're comps are 4ohms, you cant make the amp see 2 ohms on each. unless you can bridge two channels to mono and wire your comps in parrellel... but that wouldn't be bright.
so why do virtually all companies state that u get an increse in rms by running your speakers at 2ohm loads... i don't get why they even mension that then if its such a bastard to pull off and obviously isn't a stable idea... thnx anywayz
amp companies.
this is something that you should think about before you either: a.) buy your comps -or- b.) buy your amp.
Zinthesis
Zinthesis
Perth, Western Australia
Nikuk
