What does this mean on an oscilloscope?
TDot
Bronx
I only tested this out the amp, so it might be caused by the 360.3, which I doubt; or the car itself. However, I'm asking if this could be caused by bad power? Or simply what would be the most common cause of this, and the best way to narrow it down and repair. No big 3, I'll consider that once I've narrowed this down to specifically needing that.
Can the bad signal be due to power/grounding, or is it strictly an audio issue?
If it can be power/ground can I hook the oscilloscope up directly to the distribution blocks to see what's happening? If so, what settings should I set the scope to?
Cool, thanx for the correction, I'm still learning too.
no prob, a square wave will look like like a wave with squared off tops and sides. too lazy to post a pic, so just google it.
I have a scope and mine squares off as well. So what does this mean? Light clip?
if it is a total square wave that is bad. full clipping. you dont want to clip at all
Can the bad signal be due to power/grounding, or is it strictly an audio issue?If it can be power/ground can I hook the oscilloscope up directly to the distribution blocks to see what's happening? If so, what settings should I set the scope to?
youre settings seem to be correct, 2v divisions, but try to set the ms higher or lower. been a while since I used a scope.
I set my gains so I have a smooth wave. Just never noticed it looking like his picture. Might need to make it larger then try it agian. Just so I can try and replicate this. Always learning
What you're looking at might not be "real". It could be noise being picked up by your connections. The fuzzy sides and non symmetrical look kinda indicate that. Also, your waveform is off the screen. The bottom half of the signal can't be seen. You could be driving the scope input into a nonlinear region.
You need to get the scope trace centered with no offset so you can see the entire waveform. I assume you're looking across amp output terminals and there should be no DC offset there, but doublecheck that with a DMM.
38
360
10
973
TDot
TDot
Bronx
pawn man
    May 20, 2024
    May 20, 2024
