What does running "active" mean?
If you have a 4 channel amp, but you need a separate channel for each speaker.
6 speakers...... you need 5 channels of amplification.
not sure i understand 5 channels for 6 speakers unless of course you are stating 1 channel for sub. but in a typical f/r/sub config, i would assume you need 8 channels for 2 sets of components plus a sub channel, so 9 total channels in that case or 7 in a front component, rear coax, sub config?
Is it still considered being "Active" if your using the x-overs built into the amp? I thought the signal going to the amp needed to be "filtered" before it hit the amp to be considered active... //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Example:
Channels 1&2 are crossed over at a certain freq for the mds only and channels 3&4 are crossed over to play tweeter freqs.
The only benifit i see in this setup is the removal of the passive x-over...
Example:
Yes its still considered active although it can be hard to tell exact x-over frequency. The benefit is the increased tuning capabilities.
38
371
10
976
RCobra07
RCobra07
Orlando, Fl
PaulD
    May 22, 2024
    May 22, 2024
