What do ya'll have your low pass filters set at?
It depends on a lot of factors; your sub, your midbass drivers, the type of filters used (LR or BW), and the output levels of the amplifiers to the respective drivers.
Depends on what I'm listening to...Rock/acoustical music: HPF 50hz 18db/octave) LPF: same
R&B: HPF 63hz LPF 80hz
Bass Heavy music/Hip hop: HPF 100hz LPF 80hz
yup its variable for me too ....there is no "one setting" for anything i own
If your last problem was the same as this one, you know exactly where to start. Does it change based on vehicle speed or engine speed? Does the...
125
620
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
763
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
ckunke002
ckunke002
Portland, OR
subzero
Decebal
    Jun 10, 2024
