john_dmx 10+ year member
1600 WATT AMP + TWO 12 INCH 1600 WATTS SUBS AND THE HEAVY DUTY AMP KIT
The subs are audiobahn 1600W
the amp is 1600 w VOLFENHAG
(1600W 640 W *320Wx2CH@2ohm(640W)
440 W *220Wx2CH@4ohm(440W)
*Bridged Power 640Wx1CH@4ohm
2ohm stable stereo
Tri-mode capable
Fan cooling system
Variable bass booster :0-18dB
Variable bass frequency:30Hz-100Hz
Channel seperation:>60dB
Signal to noise ratio:90dB
THD 0.03%
Frequency response:20Hz-20KHz
HPF:50Hz-1KHz
LPF:30Hz-250Hz
Adjustable sensitivity range:0.1V-1V
Input impedance:Low level(10K ohms), High level(100 ohms)
Dimension(WxHxL)mm:262x59x429
and a AMP KIT BY POWER ACOUSTIK
FOR $299+shipping($45)
2ohm stable stereo
Tri-mode capable
Fan cooling system
THD 0.03%
HPF:50Hz-1KHz
LPF:30Hz-250Hz
