what do i need
  • 2
its not recommended to run that amp at 1.5 ohms, but it can be done. just make sure it has really good ventilation and if ur not cranking ur music all the time, it should do fine. to run 4 of them i'd suggest u get 2 of those amps. if u wanna play it on the safe side, get a 1 ohm stable amp, then u dont have to worry about heating problems.
527
386
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
423
629
mario
mario
Tuczon, AZ
SuckMikeHawk23
