What do i need to put a setup in a car with nothing?
Only need the harness that came with the HU and the partnering wires in the dash..... if they're still there //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and is the harness that came with it readily available if i left it in my old car which i no longer have? as in can i order another one from pioneer premier?
You'll need an adapter to go from the vehicle's wiring to whatever head unit you'll have, plus wiring for the amplifiers, and runs of speaker wire to the doors.
what vehicle wiring needs to be hooked on? i was under the impression that the vehicle harness had wires such as Remote Turn On and wire running to each speaker, and maybe a power antenna wire? as you can tell i've never installed anything myself...
just need constant 12+v, ground, ignition wire, and antenna if u listen to the radio, Then RCAs to amps, remote to amps, and amps to speakers/subs. Done
that was more what i was thinking was necessary. the ignition wire would act as the remote turn on right?
After using prebuilt adapters on mine, I won't go back //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Individually soldering and heatshrinking wiring harness leads is about my least favorite activity in car audio...a runner up to sound deadening, but even with deadening you get the feeling you're accomplishing something //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
heatshrink!?!? Stop filling yne's head with all of this nonsense! We need wires twisted together and covered in bubblegum! //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
yne721
SWINE FLU!!!!
yne721
Maui/Detroit
phyphoestilic
